I started the day by riveting on the ELT mount reinforcing plate, bolting on the ELT mount and strapping in the ELT. Next I fabricated a bracket to support the end of the aft fuselage wiring harness support rail and riveted on the bracket. Then I attached a D-sub connector to the wires for the elevator trim servo and mounted the connector to the bulhead forward of the ELT. Lastly I bolted on the seat belt upper attach point restraint cable.
